Flexible Brake Lines for Cleveland Brakes
dtpilot
Post by dtpilot »
I have Cleveland wheels & brakes on my 120. The previous owner removed the wheel extenders, and when doing so, replaced the flexible rubber lower brake lines with aluminum tube lines. The right brake rubs the rotor when taxing, as the hard line does not allow the caliper to float properly. Does anyone know where I can get the flexible brake line assemblies? Thanks!
Re: Flexible Brake Lines for Cleveland Brakes
Any A&P with the proper mandrels can make them for you, or, A.E.R.O. has a hose shop that I used to order from.
Post by 6277 »
Good advice. I removed my wheel extenders and my APIA made some flex hoses for me. Not hard at all. Taxis and tracks better w/o the extenders :D.
