oil temperature adaptor
8466
- Name: Thayne I
I replaced a used oil temperature gauge recently but my AMT encountered a problem. The sensor is inserted into a adaptor with a threaded collar. The adaptor if that is what is called (I can't seem to find in any parts catalog) is threaded into oil screen assembly (part # A3568) on the crankcase cover. Unfortunately what the AMT encountered was the threaded collar is smaller diameter (5/8, 18 thread pitch) than the original oil temperature gauge sensor collar. So my question is what is the number of this adaptor that has same male size as I have now and a female 5/8" 18 thread pitch?
Happy flying.
- Name: Mac Forbes
Re: oil temperature adaptor
The adapter is part of the gauge. You cannot guaranty mix and match, even if both gauges are the same brand.
- Name: Thayne I
Thank you very much. This is just the info I need.2066 wrote: ↑Fri Feb 12, 2021 6:06 pm download/file.php?id=137
Hopefully this ^ link will work -- I believe it'll answer.
Thayne inman
Happy flying.
