C85 Magneto choice
7698
Aircraft Type: C120 - GAKVM
Re: C85 Magneto choice
Post by 7698 »
7981 wrote: ↑Fri May 01, 2020 5:22 pm Just swapped out my Eisemann's for TCM with harness. Slick's are OK. I have always had better service from TCM/Bendix. Don't forget spark plugs and "P" lead inspection to finish out the installation.
I would be interested in your list of parts purchased..
Where they overhaul exchange units?
Did you buy a harness set complete, ie a set that inclusded L & R or individuals.
Did you need to purchase fitting clamps as the Eisemanns have a slotted lobe that fits over the studs.
2356
Occupation-Interests: Retired
Post by 2356 »
My Slick conversion came with a harness. I don’t remember the hold down clamps. You may need to modify the P leads.
phil123
Aircraft Type: C140-O200
Post by phil123 »
You might look into this new magneto from surefly its a solid state with no impulse and a hotter spark, replaces one of the bendix or slick impulse coupled mags and takes the slick harness, If I had to replace a magneto I would seriously look into putting money into this. https://www.aircraftspruce.com/pages/ep ... -17074.php
Post by V529 »
phil123 wrote: ↑Wed May 06, 2020 9:27 pm You might look into this new magneto from surefly its a solid state with no impulse and a hotter spark, replaces one of the bendix or slick impulse coupled mags and takes the slick harness, If I had to replace a magneto I would seriously look into putting money into this. https://www.aircraftspruce.com/pages/ep ... -17074.php
Ditto, my next magneto replacement will be one of these units. I've seen a few installed and so far they are working great.
Aircraft Type: 1946 C120
Post by 8233 »
V529 wrote: ↑Thu May 07, 2020 10:45 am Ditto, my next magneto replacement will be one of these units. I've seen a few installed and so far they are working great.
Hey Victor. Maybe you can confirm but it looks like I wouldn't be able to use the SureFly on my 120. The reason, I did the Odyssey battery conversion and according to the SureFly requirements, a 12 volt battery must have a minimum capacity of 20AH. Looks like the Odyssey only has 15AH. I could be reading this wrong but if I'm not, that would be something to keep in mind. This was from the SureFly installation instructions:
"2.4. Power Requirements:
The airframe must be equipped with a 12-Volt battery having a minimum capacity of 20AH or a 24-Volt battery having a minimum capacity of 8.5AH."
David Freeland - CFII
7981
Occupation-Interests: A&P /IA retired
Post by 7981 »
7698 wrote: ↑Sat May 02, 2020 5:47 am
Sorry for the delay. ( Covid ya know ) I ordered a kit from Aviall. Came with harness. Plugs extra.
