2020 Calendars in store
Aircraft Type: 48 140 C90
Post by 6898 »
Go to store and under "Gear" calendars are now available.
6863
Re: 2020 Calendars in store
Post by 6863 »
So Jeff, are you telling me the reason I have not received a calendar is because I will need to buy one from the store if I want one?
John Kliewer
Rob Swanland
Aircraft Type: C-140A
Post by Rob Swanland »
John, you will receive a calendar as an active member. Here is some further explanation for you and any other members that have not yet received the calendar... The calendars are mailed using USPS "bulk mail". The problem is that there is really no guaranteed delivery time for bulk mail. Unfortunately a small percentage of our bulk mail is delayed well past what seems reasonable. I have seen bulk mail delivered as late as 60 days after mailing. Next year we plan to mail the calendars well in advance of January 1 to adjust for the bulk mail timing problem. Now, back to your message, we are preparing a second mailing for those that did not have correct addresses in their member profile. We will make sure a calendar is mailed to you, via first class mail. Please do let us know when the original bulk mailed calendar finally shows up. Thanks for your patience... Rob
6863
Post by 6863 »
Thank you Rob for the explanation. My address has not changed since I joined the Association so it should be the same as always.
John Kliewer
Post by 6898 »
John.Rob has explained it and I apologize for any confusion all 2020 members will receive a 2020 calendar.
6863
Post by 6863 »
No problem Jeff. Thank you for your response and for your diligent work.
John Kliewer
Rob Swanland wrote: ↑Tue Jan 28, 2020 6:34 pmThe calendars are mailed using USPS "bulk mail".
I'm not sure what the pricing for "Bulk Mail" is, but maybe the Assn should look at "Media Mail" instead. It's a lot less than first class, and has been nearly as predictable for me. I think with Bulk mail the PO assumes zip code order, and if anything sticks together or is out of order it can get sent to the wrong corner of the globe.
OTOH, they seem to get those useless advertisements and political flyers out on time...
Aircraft Type: C140A
Post by 8474 »
Received my calendar yesterday in Canada, great job with the photos. It has a place of honour on my wall.
5469
Name: Horacio Berardone
Post by 5469 »
Hello,
I got my calendar last week in Buenos Aires.
Beautiful set of photographs !
Is in my living room african wenge book shelve !
Thanks a lot,
Horacio
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
