Glide ratio
Moderators: 6183, 6643, V529
8263
Aircraft Type: 1946-140
Occupation: Journeyman wireman
Glide ratio
Post by 8263 » Thu Oct 10, 2019 10:42 pm
Hello all. Could someone please tell me the glide ratio for a cessna 140? Thank you all.
Pat
Name: John von Linsowe
Aircraft Type: 48 C-140
Occupation:
Re: Glide ratio
Post by 5806 » Fri Oct 11, 2019 7:15 am
I have heard... a little better than 7:1.
Semi-related to the subject, it varies under different weight loadings but in my airplane about 1600 rpm the "glide ratio" is similar to a low performance sailplane. Circling in thermals can actually produce a climb on a good day.
John
8482
Aircraft Type: '46 140
Occupation:
Re: Glide ratio
Post by 8482 » Fri Oct 11, 2019 10:50 am
I'm guessing you are wanting this for Foreflight? I use 7. I hope that is a conservative number if I ever needed to rely on it. But yeah, loading and environmental factors can affect that number as previously stated.
Rob Swanland
Aircraft Type: C-140A
Occupation: Website & Forum Administrator
Re: Glide ratio
Post by Rob Swanland » Fri Oct 11, 2019 12:03 pm
Yes, 7:1 is very conservative but better to be on the safe side. Lightly loaded you should be able to achieve 10:1, maybe more if the prop is not windmilling.
8263
Re: Glide ratio
Post by 8263 » Fri Oct 11, 2019 12:22 pm
Yes it is for foreflight. 7:1 it is. Thanks for the response guys
Pat🤙
Post Reply Previous topicNext topic
Who is online
Users browsing this forum: 6643, Bing [Bot] and 1 guest
