Carb Heat and Cabin Heat SCAT Tube Drain holes
A collection of technical articles & attached documents by Neal Wright
Locked
101
Post by 101 »
Originally Posted on Wed Jul 20, 2005 12:34 pm
This is an update of a file which suggests the advisability of adding drain holes in the SCAT tubing used for carb heat and cabin heat.
Rain water collects in the tubes when the plane is sitting in rain and when being washed. It waits there to corrode the wires of the SCAT tubing and to strangle the engine with an unwanted slug of water or to surprise the cabin occupants when the water is flushed into the cabin when heat is selected.
Neal
scat_tube_drain_holes.pdf
To prevent the collection and retention of water in the SCAT tubes used in the carb heat and cabin heat systems, it is suggested that drain holes be made in the SCAT tubes at their low points.
(31.92 KiB) Downloaded 1930 times
Locked
