Window latches
Re: Window latches
The FAA would call it a minor alteration and it would require an A&P to sign it off.
What I was attempting to point out was that there is a list of things the FAA allows pilots to do and sign off.
Funny the FAA does not consider preventive maintenance, "maintenance" their definition is:
"Preventive maintenance means simple or minor preservation operations and the replacement of small standard parts not involving complex assembly operations".
As I mentioned previously, please ask for the assistance of an A&P to walk you through the steps to complete the project properly.
Aircraft Type: C140 / O-290
Re: Window latches
Post by 8455 »
All good discussion regarding sign-offs and 337s.
What I want to know is - what happened with the original idea of a replacement that resembles the original latch? :)
Re: Window latches
8455 wrote: Tue May 14, 2019 2:28 pmWhat I want to know is - what happened with the original idea of a replacement that resembles the original latch? :)
Univair already supplies a PMA approved replacement for the original latch; it's just obscenely expensive...
8402
Re: Window latches
Post by 8402 »
I'd be interested in a set.
Walt
'46 140
N89009
8455
Re: Window latches
Post by 8455 »
Yep, the Univair copies are expensive...
I've PM'd the member who originated this thread.
Re: Window latches
Post by 8170 »
I am still working this. I am in the midst of a move from AZ to Louisiana but When I get settled I will continue with the project. Thanks for your understanding.
Joe
8398
Re: Window latches
Post by 8398 »
What about 3d printing the latches?
8272
Occupation-Interests: Student
Re: Window latches
Post by 8272 »
I am interested. Had a fastener pop out on me in flight once, and left me clueless as to the hardware required to fasten the window to the latch.
8455
Re: Window latches
Post by 8455 »
Hi Joe!
Thanks for your response, and good luck on the move!
Terry
8423
Re: Window latches
Post by 8423 »
Are these latches still available? If so, I would love a pair.
Thank you
