firewall Rivets
monceaviation
- Name: Mike Monce
- Aircraft Type: 1946 140
- Occupation-Interests: AP IA
firewall Rivets
Does anyone have the P/N for the Flat head rivets used on the fire wall?
Re: firewall Rivets
If you don't get an answer here, you can contact David Lowe through the members section on the main web page. David has the Cessna drawings that will list the correct rivet.
8425
- Name: John G
Re: firewall Rivets
Those rivets are AN442AD4-x. Univair has a small selection of sizes required. You will also need the proper rivet set. Rivets and the set are available with a Google search.
Re: firewall Rivets
Whenever we did firewall repairs (stainless steel or ternplate metal) we used monel rivets instead of aluminum rivets.
