Any tips to make my heater work any better. Warm air gets just inside the firewall then kinda disappears!
Cabin Heater
8209
- Name: Brent Wilson
Re: Cabin Heater
What exhaust system do you have? Patch up all the holes and leaks in the heat muff, make sure you have good ram air pressure going into the muff, and stop all the cold air from coming into the cabin.
Re: Cabin Heater
Thanks John,
I have the 150 exhaust. Didn’t really think about it leaking around the shroud I will have to check that out. Cabin is pretty good at this point, doors are reall good, maybe a little leaking in the top corners of the windshield. I have the vent holes in the wings blocked off so not much coming through the vents. Just need to work on getting a little flow out of the warm air.
Re: Cabin Heater
A recent new member bought a 46 140. Sometime in the aircraft's dim dark past, the exhaust was upgraded to the C-150 exhaust. They also installed the standard heat shroud around the muffler from a later 150 which has a 3" scatt outlet to the cabin, as opposed to the standard 2" that comes on all the 120/140 aircraft. (you need a matching inlet riveted to the firewall of 3" flange so the larger scatt will work) So of course they riveted a larger heat valve/flange to the fire wall.
Bottom line, the member had flown in my aircraft (standard 2" configuration) and while we didn't freeze while flying in 40 degree OAT's, we weren't exactly cozy warm.
With his new airplane they had not only adequate heat, but surplus heat with OAT's in the 30's. This is an option if you want to work out the details of getting the larger scatt worked out with your A&P.
Between sealing any heat loss and cold air entering the cabin and this mod, you would never be cold again. (except on start up!!!
8209
Re: Cabin Heater
Thanks for the heads up on the 3” hose. I will check that out along with making sure I have eliminated as many leaks as possible.
Also here in Wyoming warmer weather is only 90 days away.
8322
- Name: Raymond H
Re: Cabin Heater
Victors not stretching the truth! I ﹰswear you could bake cookies with that thing! Ok well thats stretching it but yea theres plenty of heat even with numerous anti-CO features of the cabin!
In fact on the 120 / 140 club fb page a gent posted about his doors sucking out a bit at the backside upper area making it really cold. I thought " glad mine dont do that" i looked next time out and well by God i do have that same issue...
Im really happy someone set it up like this, makes winter flying much more pleasant!
vindio
- Aircraft Type: C120
Re: Cabin Heater
So, we're considering the mod Victor describes, while the airplane is in for annual ('47 C120).V529 wrote: ↑Mon Dec 24, 2018 11:03 am A recent new member bought a 46 140. Sometime in the aircraft's dim dark past, the exhaust was upgraded to the C-150 exhaust. They also installed the standard heat shroud around the muffler from a later 150 which has a 3" scatt outlet to the cabin, as opposed to the standard 2" that comes on all the 120/140 aircraft. (you need a matching inlet riveted to the firewall of 3" flange so the larger scatt will work) So of course they riveted a larger heat valve/flange to the fire wall.
Between sealing any heat loss and cold air entering the cabin and this mod, you would never be cold again. (except on start up!!!![]()
Does anybody have any part #'s for the 3" C150 heat shroud, and the 3" inlet for the firewall?
v
Re: Cabin Heater
You will need to find either the parts book for the later C-150's. (mid 1970's, before they started making the C-152) to get the exhaust shroud p/n. I'm sorry the parts book I have at home this weekend stops at 1969 and that appears to still have the smaller size shrouds on it.
For the "flange" to be installed on your heater valve on the firewall, Aircraft spruce has mulitple sizes. It appears the 3" is: 10350-12
The exhaust shroud for the muffler will probably be a 0450400-201(OEM number)???
https://www.aircraftspruce.com/catalog/ ... p4QAvD_BwE
But look into it before purchasing.
Re: Cabin Heater
Could you just change the flange on the existing shroud?
Re: Cabin Heater
1976 parts book datedYou will need to find either the parts book for the later C-150's. (mid 1970's, before they started making the C-152) to get the exhaust shroud p/n.
