ID plate
bc12d
ID plate
Post by bc12d »
Can some one chime in , where I can find the Mounted Manufacturer ID plate is on a 46 Cessna 140 ?
dcannon
Aircraft Type: 1946 C120
Re: ID plate
Post by dcannon »
Door post or glare shield. As they are prominent I am guessing yours might be missing. I went through the process of a replacement data plate. Cost me a few months of waiting and almost $3000.
bc12d
Re: ID plate
Post by bc12d »
Thanks for your quick reply.
bc12d
Re: ID plate
Post by bc12d »
Can you say which door post upper or lower or where on the glare shield, some one in the past has covered all those areas with glued on Vinal.
ken_k
Aircraft Type: 120
Re: ID plate
Post by ken_k »
The data plate is located on the lower left door post or on the left upper surface of the glareshield.
