Spongy brake
atypicalguy
- Name: Karl
Re: Spongy brake
I figured there must be a line in there not doing well, but I was hoping for a leaky connection. Oh well. No wonder the PO didnt fix it.
atypicalguy
- Name: Karl
Re: Spongy brake
I dont see how this could be such a slow leak if it is perforated, but stranger things have happened I suppose. Maybe a pinhole.
atypicalguy
- Name: Karl
Re: Spongy brake
Turns out this was just a loose connection after all in my case.
seberggelet
Re: Spongy brake
Started having similar issues and saw a leak coming from the brake line under the RH gear leg once I removed the RH inspection cover under the seat.6863 wrote: ↑Fri Jun 11, 2021 7:30 amatypicalguy, it sounds to me like you've got the same problem I have had. Twice now I have had to remove the RH gear leg and replace the 6 inch long horizontal brake line that connects to the top of the gear leg brake line. It is very difficult to access and very difficult to fabricate and get the angles just right. In my case the root cause of this problem was a PK screw which fastens the gear leg fairing to the fuselage puncturing through that six inch long horizontal brake line. Needless to say I am no longer using a PK screw through that particular hole.atypicalguy wrote: ↑Thu Jun 10, 2021 11:04 pm I have a brake fluid leak that does not seem to be coming from the master. It is within the fuselage somewhere and is a slow leak requiring a top up of fluid every 20h or so. A drip forms on the belly every so often. What are the potential leak points downstream of the master cylinder but still within the fuselage? 1946 140. Clevelands.
Thanks.
Looks to me like I would have to remove the gear leg to get at that section to replace/repair...
6863
- Name: John Kliewer
Re: Spongy brake
Unfortunately I think you are correct about having to remove the gear leg. I hope I'm wrong about that.
John Kliewer
7698
- Name: TailWheelCharlie
- Aircraft Type: C120 - GAKVM
Re: Spongy brake
Having started this post with a spongy left brake, Ive recently dealt with a leak on the right in exactly the same place.. Your right, its a pain to get to and I have the scars to prove it.seberggelet wrote: ↑Mon Jul 19, 2021 12:06 amStarted having similar issues and saw a leak coming from the brake line under the RH gear leg once I removed the RH inspection cover under the seat.6863 wrote: ↑Fri Jun 11, 2021 7:30 amatypicalguy, it sounds to me like you've got the same problem I have had. Twice now I have had to remove the RH gear leg and replace the 6 inch long horizontal brake line that connects to the top of the gear leg brake line. It is very difficult to access and very difficult to fabricate and get the angles just right. In my case the root cause of this problem was a PK screw which fastens the gear leg fairing to the fuselage puncturing through that six inch long horizontal brake line. Needless to say I am no longer using a PK screw through that particular hole.atypicalguy wrote: ↑Thu Jun 10, 2021 11:04 pm I have a brake fluid leak that does not seem to be coming from the master. It is within the fuselage somewhere and is a slow leak requiring a top up of fluid every 20h or so. A drip forms on the belly every so often. What are the potential leak points downstream of the master cylinder but still within the fuselage? 1946 140. Clevelands.
Thanks.
Removing the gear leg would have made this easy, but I didnt have the stands and expertise to do so; so I compromised.
As you mention, getting the angles correct will be difficult and thats before you try and get the pipework back in... So I went for flexible pipe and fittings from Goodridge 600 series pipe and fittings.
Yes, its still hard to get to the positions, but I managed it with a small amount of bad language...
I ended up making up the pipe and fittings and pre fitting the bulkhead fitting that is on the internal forward facing wall of the gearbox... Hopefully that makes senses.
A small angled pipe spanner would have helped, but I didnt have access to one, so ended up taping a small open ended spanner to a finger so I didnt drop it into the gearbox... Definatley a test of patience
