For Sale 1946 C140 (C-FJAR) Has to go - Price Reduced!
Moderators: 6183, 6643, 529
Occupation:
Post by 5115 » Thu Jan 24, 2019 12:13 am
The process to re-import a US manufactured plane from Canada back to USA is not difficult. Don't stop yourself from considering it. :P
1946 CESSNA 140 • $25,500USD • FOR SALE • Very well maintained, multiple STCs, flies regularly
Airframe TT: 3608 hours., Engine TTSO: 1243 hrs, STOH: 205 hrs
Engine: Continental 0-200 (STC) with 205 hours STOH (4 new Millenium cyl.). McCauley Prop 1A101 (69-48) as per Randy's STC with static at 2600rpm.
C150 Exhaust STC, MOGAS STC, Cowling latches STC
Brand new Harness and Slick Magnetos 4301with under 10 hrs on them. TAF-L Spin-on Oil Filter, 60 amp Alternator
McCauley wheels/brakes. Refurbished Scott 3200 tailwheel, new pressure plate, new chains/springs and new tire.
New Main tires and tubes.
Interior: C-150 newly upholstered seats with AeroFabric shoulder harnesses and belts (with STC) and new belt metal retaining bracket as per SB25-03. New carpets. Molded plastic interior restored (made for the C140), Hat shelve
Avionics : iCom A210 comm radio with integrated Intercom and Dual watch frequencies, King KT76A transponder with new transponder antenna
Instruments: Airspeed, Alti, VSI, Directional Gyro, AH, Turn Coordinator. Astrotech chrono, CHT, EGT, Oil temp (new), Oil Pressure, manifold pressure, Map light
Flown regularly. Annual inspection completed in May 2018.
Located in the Montreal, Canada region: look at airport CSA2
For more information, pictures and questions you can PM me. Many more pictures if you require
IMG_3284 - copie.jpg (196.05 KiB) Viewed 516 times
IMG_3283 - copie.jpg (231.19 KiB) Viewed 516 times
IMG_3280 - copie.jpg (206.34 KiB) Viewed 516 times
Martin Tanguay
Occupation:
Re: For Sale 1946 C140 (C-FJAR) Has to go - Price Reduced!
Post by 5115 » Sat Mar 16, 2019 1:23 pm
Price adjusted!
Thank you for looking!
Martin
Martin Tanguay
Occupation:
Post by 5115 » Sun Apr 14, 2019 7:29 pm
Still for sale, spring is around the corner!.
Let me know if any questions.
Thank you for looking.
Martin Tanguay
Post Reply Previous topicNext topic
