150 Exhaust STC
- Name: Blaine F
- Aircraft Type: C140A
150 Exhaust STC
Does anyone have the contact info for Walter B Thomas, holder of STC SA648NE
- Name: David Freeland
- Aircraft Type: 1946 C120
Re: 150 Exhaust STC
Actually, it's now owned by Ken & Lorraine Morris. More info here:
https://taildraggeraviation.com/stc-150-muffler-home/
David Freeland - CFII
Re: 150 Exhaust STC
An updated page in the "Resources" section of the Web Site should be available shortly.
- Name: Blaine F
Re: 150 Exhaust STC
Ok, thanks!
- Name: Raymond H
Re: 150 Exhaust STC
Not sure how it works, if theirs covers this or not, but when mine was done in 1980 they used the 150 setup that pulls heat off both sides... I know our gals have a reputation for low heat output... Mine with that set-up will cook you out...
- Name: Blaine F
Re: 150 Exhaust STC
Lorraine got right back to me and she has sent the STC. I'm planning on using the Wag-Aero kit https://www.wagaero.com/engine-parts/ex ... stems.html When I get around to doing the conversion. Although I have not seen the STC paperwork yet it looks to me like the one scat hose goes to the heater from one side and the other goes to the carb heat from the other side.
- Name: Samuel G
- Aircraft Type: '46 140
Re: 150 Exhaust STC
This may be a redundant question but I need to be sure...This will fit on my O-200-A right?8474 wrote: ↑Wed Oct 02, 2019 9:42 am Lorraine got right back to me and she has sent the STC. I'm planning on using the Wag-Aero kit https://www.wagaero.com/engine-parts/ex ... stems.html When I get around to doing the conversion. Although I have not seen the STC paperwork yet it looks to me like the one scat hose goes to the heater from one side and the other goes to the carb heat from the other side.
Re: 150 Exhaust STC
All C-series Continentals, including the O200, and I believe, all A-series Continentals, have the same exhaust port spacing.
- Name: John von Linsowe
- Aircraft Type: 48 C-140
Re: 150 Exhaust STC
Hello Raymond,
Curious if the carb heat is shared with cabin heat on one side?
John
- 5806
Re: 150 Exhaust STC
I would like to add a solution to a problem I had on my 0-200 exhaust installation. The baffling aluminum sheet wrapped around the mufflers have the clamping angle riveted to it. The thin aluminum would become deformed and the rivets would pull. I added a doubler under the angle that extended a couple inches around that baffling. I think these were obtained from Wag-Aero.
I might find a good photo of this and will post it.
John
Users browsing this forum: Bing [Bot] and 16 guests
