Approved Flight Manual
- gryph0n
- Name: Steve S
- Aircraft Type: 1948 C-140 O200
Hello All,
The C 140 Type Certificate Data Sheet requires this piece of interior equipment:
403. CAA Approved Airplane Flight Manual (optional nomenclature:
"Approved Operating Limitations") and pertinent revisions applicable to the particular model and serial
number.
I was previously under the impression that the 120/140 Operations Manual fulfilled this requirement, but the Ops Manual makes reference to “the CAA Approved Airplane Flight Manual”, so it can’t be it.
Where does one find said Manual?
Thanks, Steve S
number.
Thanks, Steve S
- Name: Huey Pilot
Re: Approved Flight Manual
The original was a two page type written document that had specific data for each aircraft. Weight and balance, optional installed equipment. Hopefully it’s in your paperwork.
It's Form ACA-309. It should be in your permanent aircraft records. If not, order the FAA CD for your plane. It should be in there. I'm attaching mine, so you can see what it looks like.
I'm guessing there is a large percentage of the fleet that is not carrying this document... Mine's not up to date: I have a C90 now.
- ACA-309.pdf
- (273.23 KiB) Downloaded 604 times
- gryph0n
- Name: Steve S
Helpful, thanks John and George.
- Name: Ray Hunter
Here's what I thought
was the Approved Flight Manual.- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
Ray,
I believe you are correct. See attached Service Letter from the library that states CAA Form 309 is no longer needed in favor of what you posted.
- Airplace-flight-manual.pdf
- (37.97 KiB) Downloaded 429 times
David Freeland - CFII
- Name: Blaine F
- Aircraft Type: C140A
- regular122
- Name: Steve
- Aircraft Type: 1948 C140 C90
Is there one for a 140 with a Continental 90?
Steve
Steve
Mine is for a C85 with a few things crossed out and the correct values penciled in.
- Name: Mike Smith
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
