Favorite/best inner tube brand?
- Name: Daniel
My 6.00x6 inner tubes are starting to show their age and I’ve had a couple flats already. I’ve been able to patch the tube every time but I’m getting the impression I’m just going to keep chasing it.
A quick look a Spruce shows a multitude of brand and price choices. Is there a recommended brand?
I have Cleveland wheels, if that makes any difference.
- Name: Huey Pilot
Re: Favorite/best inner tube brand?
I have the Leak Guard tubes with the metal vale stems. They hold air very well. Got them at Desser tires.
- Name: Mac Forbes
+1 for Desser's Aero Classic Leakguards...they really do hold the air! Mac
Are you in advertising?
"Desser's Aero Classic Leakguards...they really do hold the air!"
- Name: Mac Forbes
- Name: Daniel
The Desser Leak Guards are actually cheaper than most of the other brands - seems its the right way to go!
So I don’t have to start a new thread, does anyone know the part number for the cotter pin used on the axle nut? I’m coming up blank on it with the parts catalogs.
AN380-4-3 (MS24665-351) Two are used on each wheel, 180 degrees apart from each other. You can use MS24665-360 if you want to use just one, but you'll have to bend it into a curve to get it through the axle.
- Name: Daniel
One more question: is it necessary to repack the bearings while I have the wheel split? I didn't previously when I was changing the flats but the fact I had my plane blocking a taxiway factored in.
- Name: Raymond H
Keep em in good shape boys, and check that pressure! I blew one landing at KMKG a few weeks ago, didn't loop but couldn't get it off the runway either. Thank God for Mr Victor Grahn, how "lucky" could I be landing at his airport when I had a problem! I did delay him in leaving for convention from the blow out... My apologies there... I believe I'm not indebted for steak dinners whenever we are together now for life! lol.
But seriously folks, it was a major inconvenience, but luckily didn't deflate bad till just above taxi-speed, but could have turned out worse. His people there got me a new one and I flew it home a week later. I had visually inspected tires in preflight and looked fine. However after the blow out, I found that the one that didn't blow was down to 14psi, and "looked" fine, hardly noticeable to the eye compared to the "Just shy of 20" I usually use... I will for now on be checking em with a gauge on a regular basis...
- Name: Mike Smith
Wouldn't hurt. It would give you a good chance to take a close look at the condition of the bearings.
Users browsing this forum: No registered users and 15 guests
