Auto Reset Breaker in C-140A
Posted: Tue Dec 30, 2025 3:44 pm
Hi New Member here.
I am a AP IA working on a friends C-140A and this AC has an electrical issue. As you add load to the DC buss by switching on the electrical loads starting with the master switch on the left then proceeding to the right there will eventually be a total loss of DC buss voltage. By switching off all the loads including the master and a brief wait, you can once again switch on the master and then additional loads until the trip re occurs. There seems to be a auto reset type of thermal breaker in the circuit that is tripping, cooling, then auto resetting. However I don't see such a breaker in the panel or when looking at the different electrical wiring diagrams, such as the early C-150's. Any feedback appreciated.
Brian in So CA
Brian in So CA
