Pull Starter
Posted: Sat Jul 05, 2025 10:08 pm
by tomreneau
Anyone have an extra pull starter cable with a knob and not a t handle sitting around?
Re: Pull Starter
Posted: Wed Jul 09, 2025 10:01 am
by chewie
Would an old mixture control work? I think I still have one in the hangar. Black knob similar to what you're showing. It was too short when I swapped out my carb.
Re: Pull Starter
Posted: Wed Jul 09, 2025 11:11 am
You can buy a generic cable from Aircraft Spruce. If your casing is in good condition you can often just replace the core.
https://www.aircraftspruce.com/catalog/appages/a730.php
(Boy, have the prices gone up!)
End fitting:
https://www.aircraftspruce.com/catalog/ ... -16000.php
Re: Pull Starter
Posted: Thu Aug 07, 2025 2:55 pm
by tomreneau
I discovered that the wire used in the Spruce replacement cable is larger than the original. The A730 has 050 wire and will not fit in the factory cable housing. I have McFarland working on it.
