Scott 3-24B Tailwheel Questions
Posted: Wed May 03, 2023 4:33 pm
I have two questions. First I am replacing the TW springs and chains. I purchased the U2151A-000 assembly from Spruce and the chain is larger links than original and the spring is slightly larger. Anyone know if there is a better match or method to replace the assembly? Part numbers if you know would be appreciated. Second is I want to replace the rubber in the TW leaf assembly and wonder if anyone knows what would be the correct rubber to use. Thanks for the help as always. TomR
