I replaced my ancient VR 300-14-50 Electrodelta VR with the Zeftronics G1200N. The Zeftronics unit is correctly sized to match my 20 amp generator.
It’s working perfectly. System comes on at about 1300 rpm and holds peak voltage right at 14v. I’ve noticed that my ammeter is not jiggling around anymore so I’m thinking that I had some issue with the old Electrodelta VR. So, aside from the fact that that at 50 amps it wasn’t the right size for my generator, there was some other issue and making the change was the right thing to do.
The G1200N bolted right in place on the firewall using the old Electrodelta bolt pattern. Three wires, three bolts and done. Couldn’t be easier!
During the install I had a few questions and contacted Zeftronics. I have to say that their customer service is absolutely top notch! Very highly recommended.
My A&P checked it all out and signed the logs. Good to go!
Thanks everyone for the input. Much appreciated.
Voltage Regulator Replacement
- Name: Mike
Re: Voltage Regulator Replacement
Mike Pastore, N2635N
Naper Aero, LL10
Naper Aero, LL10
- Name: Mac Forbes
Thanks for the update, Mike! It'd been several years, but your experience with the unit itself as well as excellent communication/support from the "factory" was same as mine. Quality product, quality folks. Glad it worked out! Mac
- Name: Mike
Thanks Mac!
I appreciate the input you provided. It was a great help with my decision.
All the best,
All the best,
Naper Aero, LL10
Naper Aero, LL10
Users browsing this forum: Bing [Bot] and 15 guests
