Uavionix Tail Beacon
- Name: Mike
Re: Uavionix Tail Beacon
I got my Tailbeacon a few days ago. Looks really sweet!
Only issue though is that my A&P said that the Greater Chicago FSDO is not authorizing any field approvals (337’s) for this unit. It seems odd that this would be the case. Anybody hear anything about this and/or start the approval process?
Thanks.
Mike
Thanks.
Mike
Mike Pastore, N2635N
Naper Aero, LL10
Naper Aero, LL10
- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
Maybe Chicago FSDO doesn't realize the Tail Beacon is now approved for certified aircraft? The Tail Beacon now has TSOs for the following:6930 wrote: ↑Sun Sep 22, 2019 11:20 pm I got my Tailbeacon a few days ago. Looks really sweet!
Thanks.
Mike
UAT Transmitter: TSO-C154c Class B1S
WAAS GPS: TSO-C145d Class Beta I
Altitude Encoder: TSO C88b
Position Light: TSO-C30 Type III
It looks like you should not require a field approval at all according to the document found here and you can leverage the STC AML that lists the 172 even if it doesn't specifically list the 120/140. The guidance says the 337 goes straight to OKC.
http://rgl.faa.gov/Regulatory_and_Guida ... -03-02.pdf
What he said. Have your IA read the document linked to above. It states how to fill out the paperwork and where to send it. Approval is automatic as long as there are no structural modifications.
Here's the meat:
"Submit a FAA Form 337 to document ADS-B OUT alterations. On Form 337, Block 8, include
the following compliance statement, "The installed ADS-B OUT system was shown to meet the
equipment performance requirements of 14 CFR section 91.227" along with the applicable ADS-B OUT
transmitter and GPS make/model information. Submit the completed Form 337 to the
Aircraft Registration Branch, AFS-750, P.O. Box 25504, Oklahoma City, Oklahoma 73125. The
Form 337 can be submitted directly without FAA approval in Block 3."
Here's the meat:
- Name: Mike
Thanks, John and Dave!
I thought this was the case, but wasn’t sure. I’ll run this by my guy and hopefully we can move forward.
Mike
Mike
Naper Aero, LL10
Naper Aero, LL10
- 8233
Good luck!
- Name: Mike
Thanks Dave.
I have a follow up question
So, my A&P/IA is coming today for my annual. If we mount the tail beacon, he can’t do the ground check (at least I don’t think) so he makes the logbook entry for installation and I need to take the plane to an avionics shop and the avionics shop completes the 337 after successfully testing the unit. Is that right?
Mike
Mike
Naper Aero, LL10
Naper Aero, LL10
I don't think you necessarily need an avionics shop. All you need is radar coverage to trigger an interrogation.
I seem to remember that Uavionix had a FAQ on their website that might address this question or you can also contact them.
You can also download their installation manual. The only testing you need to do prior to the test flight, besides verifying the configuration information, can be done wherever you can get the transponder to reply to an interrogation. That can be either RADAR or a test set.
- Name: Mike
Thanks John. That’s what my A&P told me.
Mike
Mike
Naper Aero, LL10
Naper Aero, LL10
Who is online
Users browsing this forum: No registered users and 16 guests
