Greetings,
I'm assembling a Cessna 140 and the bolts that connect the aileron carry-through cable to the bellcranks are missing. The bolts that connect the direct cables to the bellcranks are standard AN3-10A's, but the bolts for the carry-through cable are a special Cessna bolt (P/N 0422300). Does anyone have a "line" on a source for these bolts or an alternative?
Thank you!
Terry H.
Aileron Carry-Through Cable Bolts
- Name: John G
Re: Aileron Carry-Through Cable Bolts
That bolt is made from a AN3-6A that is trimmed to an under head length of .625.
Understood. Thank you for the info.
Tailwinds,
-Terry H.
Tailwinds,
-Terry H.
