CHT sensor probes
wingspinner
Aircraft Type: c140
CHT sensor probes
Post by wingspinner »
Can someone tell me if the c85 Continental cylinders have a CHT temperature well or must one use spark plug gasket type CHT sensors?
I’m out of town otherwise I’d just look at the airplane.
Ron
Re: CHT sensor probes
Post by 6843 »
Mine requires the gasket senders. Original cylinders.
Dave Sirota
'46 C-140 N89654
'96 Hatz N24B
KRYN
wingspinner
Aircraft Type: c140
Thanks Dave. I was hoping it had temperature wells but given the age I thought it likely that it did not. I’m ooking to buy a used engine monitor and some come with probes but all I’ve found are the “well” or bayonet type. New probes are a bit pricey and add considerably to the cost.
Ron
VIP620
Name: ken tengesdal
Aircraft Type: 120
Occupation-Interests: fly the 120 over sunflower fields and shoot blackbirds at the same time from august thru october or until the crop is harvested
Post by VIP620 »
2015 overhauled my engine and had eci nickel cylinders put on and they had a place to attach cht probes
wingspinner
Aircraft Type: c140
Thanks, most newer cylinders have the temperature wells. My 140 has the very old original type Continental cylinders which I’ve now verified do not and I’ll have to buy the gasket type.
