Originally Posted on Thu Aug 18, 2005 2:45 pm
The bolt of the rudder bellcrank under the tunnel ahead of the trim wheel sometimes rides on the inside of the tunnel and eventually cuts a groove in the tunnel and then a hole.
Cessna never formally cured the problem for the planes in the field, but they did change the design in the factory to add cutouts for more clearance and hat sections over the cutouts.
This article shows the problem and the Cessna cure.
Neal
Floor Tunnel Rudder Bolt Interference
- Name: Neal Wright
- tunnel_revised_02.pdf
- Tunnel fault and cure by Cessna.
- (44.28 KiB) Downloaded 503 times
Users browsing this forum: No registered users and 6 guests
